Civil 3D Forum
How to install object enable in autocad civil 3D 2014
1 REPLY 1
471 Views, 1 Reply
Hello Everybody
How can i install object enable for autocad civil 3d?
and how to use it in the program
thanks
1 REPLY 1
tcorey
See this link for download of 2015 version:
http://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autocad-civil-2015-ob...
Once you have downloaded the .exe file, just run it and it will install itself on any AutoCAD 2015 (and verticals) installed on the computer.
This is not a tool you add to AutoCAD Civil 3D. It is a tool you add to AutoCAD, AutoCAD Architecture and other Autodesk products so that they understand AutoCAD Civil 3D objects like Surfaces, Points, etc.
Once installed, it just runs itself. You won't even know it's there, other than that non-Civil 3D versions of AutoCAD will now be able to read Civil 3D drawings completely.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Rail Community
