I have changed the horizontal aligment.
As there is not any auto-update tool (or I dont see) I need to displace the profile 123,46 meters from 1021.27 stattion.
Any idea on how to do this easily?
Civil 3D (2013) how much you have to improve....
Joe Bouza
Mark Green
Working on Civil 3D in Canada
To Joe :
mmm I dont see help for my need at the link you gave me....
C3D 13. Design profile
Thanks,troma
I'm suspecting this is a layout profile...wish I had better methods...
1. Use the Panarama and just tab down the PVI sta and subtract values. Select the profile, right click and choose Edit Profile Geometry. Hit the Profile Grid View button and thePanorama opens for you to manually edit.
2. Copy the profile onto itself. Explode the copy (or trace a new pline on top of the profile), Move the profile block or pline to the new sta and grip edit the profile.
John Mayo
I just tested this: you can use the move command. Put ortho on, move the profile, drag in the direction you need to go and type the amount, <enter>.
Not sure why no-one else suggested it, so maybe it is glitchy. Not sure how it would work with corridors, intersections etc so I suggest saving a copy of your drawing first.
Mark Green
Thanks johnm
How ? Do you mean I have to manually edit every PVI ???????
What if I havea 20 kilometers layout with 300 PIV?
Another autodesk joke ? ufffff
Where is in this case the dynamic behaviour ?
Troma. I need to move a piece, a part, a section , from-to, of a layout or design profile.
Thanks.
Mark Green
Mark Green
Yeah looks like a 2013 feature. Just tried again in both. If you execute the move command and select the profile it moves the whole thing but it's not working with grip edits. So for the OP the question of manual editing comes down to the version.
John Mayo
Troma...
How ? I cant select with shift .....
If I do that ... the result is : nothing selected.
Can you explain me how do you do it ?
Mark Green
