Dear All
I am designing pressure pipe network for water supply line in civil 3d 2013.In that ,I am not able to insert 90 degree bends,change pipe properties know that there is default bends available in civil 3d but I need more fittings and different dia pipe. I asl know that in C:\program data\Autodesk\enu\pressure pipe fittings in that all fittings are available and SSL there is .*sqlite file available. But I Don't know to how to import this pipe fittings in civil 3d 2013. Can anybody give me solution for that. It will be grateful for me.
Kevil
Infrastructure Engineer
India
Solved by cwitzel. Go to Solution.
You can edit some aspects of the pipe library with "Content Catalog Editor"
For pressure pipes, they have added a different way to import pipes. You can find a little information here:
C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\Sample\Civil 3D APA\Part Publishing Wizard\PartPublishingWizardUsersGuide.docx.
Hope that helps, although none of it is made very easy.
Conan Witzel
Dear Conan Witzel
Thank you very much. I did this option before. Is there any other option for importing pressure pipe fittings ??
Kevil
Dear Conan Witzel
Kevil
