I'm not entirely sure what you need here. There are no points in that file, only AECC_Contours.
I'm going to assume you want a surface. In which case, there is no need for points. Explode those contours and define them as contours in Civil 3D.
thank you.
i am to do a road uni project and need to creat alignment and profiles.
i know nothing about C3D and am following tutorials of the software.
i do not need points? these contour lines are enough? can C3D identify there lines? how exactly (menus please) could i have surface from these contours?
I cannot help but bring this up. If you are doing this for "funzies" is one thing, but if this is some kind of a billable project I can see problems from a client based on your limited knowledge.
Bill
