Civil 3D Forum
how to get to "cogo input dialog box" - I dont use the ribbon , using c3d2012 64
2 REPLIES 2
caddie99
546 Views, 2 Replies
I want to try the point inverse report but I am stumped on how to get
to this dialog box?
I type 'cogo' and get to a cogo traverse box but nothing shows up about inverse report.
Is there a non-ribbon method?
Im so green at the ribbon that I type "ribbon" but still cant find it
2 REPLIES 2
tcorey
in reply to: caddie99
You can use that COGO dialog to get the report you want.
Easy way I have found is to draw a polyline through the points in the inverse. Snap to the nodes.
Type COGO.
Upper left is an icon for Load Traverse from Polyline. The inverse data will fill the bottom of the dialog.
Back at the top, be sure it says No Adjustment in the Adjustment and Balance Rules pulldown. The next button to the right is Display Traverse Adjustment and Closure Reports. Because you selected No Adjustment, this will be an inverse of  your points.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
caddie99
in reply to: tcorey
Thanks,  but I need point numbers in my report to satisfy the County surveyor.
Rail Community
