How to get precise elevations at lowest and highest points. I need to get spots where the water flows and its precise elevation at that spot as analysis.
in the surface's properties analysis tab choose elevations
if you enter 2 for the number of ranges option you will get two bands ranging from min to max elevations
it's up to you to define the ranges as close to the min and max (0.000 precision) with different colors
so when you apply an "elevation style" to the surface you will get those areas colored
and then you may label the spots.
For a really really quick check:
Change your contour interval to something "real" small. Mark it and change back to your original interval.
Bill
Your Name
Your Name
