Civil 3D Forum
How to generate reverse curve details from alignment
2 REPLIES 2
atulbhobe
479 Views, 2 Replies
can any one suggest me hw to generate reverse curve details from the alignment
i.e. i want to generate
delta
length of reverse curve
transition length
deflection angle (delta) of transition curve
shift
etc
i want them to genrate in the plan itself so help me out in doing it.
2 REPLIES 2
Joe-Bouza
in reply to: atulbhobe
Have you tried the alignment reports from the tool box tab?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People)
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win10 OS
LeafRiders
in reply to: Joe-Bouza
Go to Add Alignment Labels... Select the following Label settings.
Choose Feature: Alignment
Label Type: Point of Intersection
Point of intersection label style: Create a Style that labels exactly what you've listed.
Under the Layout tab, under contents add the criteria that you're looking for... See picture for example of the Civil 3D out of the box style. I usually start by taking one of stock styles and modify specifics. Good Luck.
Rail Community
