can any one suggest me hw to generate reverse curve details from the alignment
i.e. i want to generate
delta
length of reverse curve
transition length
deflection angle (delta) of transition curve
shift
etc
i want them to genrate in the plan itself so help me out in doing it.
Have you tried the alignment reports from the tool box tab?
Your Name
Your Name
Go to Add Alignment Labels... Select the following Label settings.
Choose Feature: Alignment
Label Type: Point of Intersection
Point of intersection label style: Create a Style that labels exactly what you've listed.
Under the Layout tab, under contents add the criteria that you're looking for... See picture for example of the Civil 3D out of the box style. I usually start by taking one of stock styles and modify specifics. Good Luck.
