how to find volume of 1*1*1 m cube by two surface method.
hello sir
i am trying to find volume of 1*1*1 m.cube.
but civil 3d volume report give me the wrong ans.
civil 3d give me 0.03m.cube why?
You probably did not start with a metric template. It appears that it was calculating the volume in Imperial units.
1 / 27 = truncates to 0.03
Bill
Apparently you need training.
But:
Bill
Just check the drawing units setting on the toolspace. Right click on the drawing name in the settings tab and click on "edit drawing settings" to check if it is set to feet or meters. Then redo the volume calc and it should come out correct.
