Civil 3D Forum
How to find certain grade (1.25:1) at existing topography
8 REPLIES 8
Message 1 of 9
artbiscocho
458 Views, 8 Replies
Hi all, I have 200 acres housing project and areal topo.. My client want me to show on my constraint map all the location of  natural grade having a slope of 1.25:1 or greater and determine the area. Is there a way using civil 3d to do it. I could do it on the conventional way of using my scale and topography plan, but it is time consuming.
Thank you!!!
8 REPLIES 8
Message 2 of 9
doni49
in reply to: artbiscocho
With just an aerial?  No.
But if you have surface data which you can use in C3D, then yes it can be done.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Message 3 of 9
rkmcswain
...I have 200 acres housing project and areal topo..
Depends on what you mean by "aerial topo". If it's vector data such as a shape file or polylines, etc. then you can turn that into a C3D surface and do your analysis.
R.K. McSwain     | CADpanacea | on twitter
Message 4 of 9
doni49
in reply to: rkmcswain
RK is correct.  In my little corner of the world, when we say aerial we mean aerial photo.  But you did specifically say aerial topo, so that could very well mean 3d vector data.
Don Ireland
Message 5 of 9
artbiscocho
in reply to: doni49
Thank you for immediate reply, yes I have surface data for the areal topography (contour and elevation). Can you help me how to do it.
Thank you!
Message 6 of 9
doni49
in reply to: doni49
Here's a really simplified example just to show you what it'll look like.  I created a surface that is just a collection of a rectangle at elevation 0.0 and a bunch of random points at random elevations.  Then I turned on "Slope Banding".  Everything in green will be 1.25 or greater.
Don Ireland
Message 7 of 9
doni49
in reply to: doni49
Here's the dwg file used in my example.
Don Ireland
Message 8 of 9
artbiscocho
It works like magic!!! I salute you buddy..
Message 9 of 9
doni49
Glad to help.
Don Ireland
Rail Community
