Civil 3D Forum
How to Fillet 3D Corners?
4 REPLIES 4
440 Views, 4 Replies
Hi Folks,
I'm proud of my most advanced grading product to date, a stormwater detention pond. It's a beautiful 3D creation. However, I need to improve it and am unsure how to proceed. Specifically, I need to reflect that fact that the contractor isn't going to construct squared corners on a pond. The points at which the sides of my pond meet the berm need to reflect a curved intersection, not a squared connection as shown now.
In case it's relevant, the berms were created separately and then pasted into the pond to create what you see now.
So, how do I improve my pond to reflect curved corners?
4 REPLIES 4
jmayo-EE
How did you build it? If you have a base polyline for the bottom use the fillet command on the sides. If you have a feature line use the FIllet Feature Line command.
John Mayo
Jay_B
FILLETFEATURE command works well for this and works on 3D poly's & Feature Lines.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
in reply to: jmayo-EE
John,
I used a 2D polyline to define the upper edge of the pond. I then used grading criteria to create the inside and outside slopes, benches, and bottom.
The berm has a 10:1 slope on one side and a 3:1 slope on the other. A bit tricky (for me). I created the berm as a separate feature line and then used grading criteria to daylight it to the shape of the inside of the pond.
So, the short answer to your question is that I don't have a feature line that defines the bottom of the pond.
Is there a different approach that would give me better results?
Pointdump
Daryl,
Small workaround--Make a Feature Line From Stepped Offset, say, .01 horizontal and 0.00 vertical, and then you can use FILLETFEATURE.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Rail Community
