Hi. I customized a surface style to show relative elevations, with lighter tones representing higher elevations, and darker tones representing lower elevations. With a single glance, I know the high and low spots in my project area.
C3d provides several default surface elevation styles. None of them comes close to providing the instant, data-at-a-glance information that my customized style does, which I use to design stormwater systems. Again, it's really helpful to see, with one look, where the high and low spots are in my project area.
I can't figure out how to export, transfer, copy, whatever, my customized style from one drawing to a new drawing. If I want to see my customized style, I have to recreate it from scratch in each and every drawing where I want to use it. It's a royal pain.
Any suggestions about how to transfer a surface style from one drawing to another? By the way, I tried opening up both drawings, with both toolspace/settings windows open. Tried dragging and dropping the customized style to the new drawing. Didn't work.
Thanks in advance for any assistance.
Did the style copy but not the expected settings, or did the style not copy at all? If the latter, make sure the drawing to copy TO is current, Toolspace is set to MasterView, expand the tree in the settings for the FROM file, go to the style to copy and drag it into the canvas of the destination drawing.
If on 2012, have youu tried the ImportStylesAndSettings command?
May be due to being based on an analysis?? (not in front of C3D so can't check)
neilyj (No connection with Autodesk other than using the products in the real world)
The term relative elevations makes me think you defined the colors on the Analysis tab of the Surface Properties. If this is the case neilyj is correct and it is not part of the surface style. I do not know of any way to export the analysis settings.
@BrianHailey wrote:
There was a tool that I believed shipped with one of the country kits that would export/import a surface analysis. Check the From The Ground Up blog.
There is certainly something in the UKIE contry kit although I have never got it to work in the way I was expecting it to.....perhaps someone can enlighten me???
One way would be to highlight the ponts in prospector, copy to clipboard and paste to excel
I think there is a step here that some overlooked. I came across this with a coworker a few weeks ago....notice the area above highlighted. It sounds like they opened two sessions of civil 3D. If that is the case, then that is where the flaw lies. In order to drag and drop styles from one drawing to another, you MUST open both drawings in the same session of Civil 3D. Then as stated by another above, in the TOOLSPACE, Settings tab; set the view on top from ACTIVE DRAWING to MASTER VIEW. THen have the drawing you want to copy TO as the active drawing. Then in the TOOLSPACE scroll down to the FROM drawing, select the style, click, hold and drag over the screen where your TO drawing is active, release the mouse button and there you go. The style is in your new drawing. If you are in 2012 you can use the import styles feature, but I have found that utilizing this tool is better if you are trying to get a multitude of styles from one drawing to another. For one or two styles, use the drag and drop method.
If this doesn't work, than I would suggest updating your template file with said style by recreating it and then always start with that template file.
Hope this helps.......
Hey people, thanks for the helpful suggestions.
I think I hit pay dirt with Brian Hailey's tip to check the "from the ground up" blog.
http://fromthegroundup.typepad.com/from_the_ground_up/2009/04/additional-tools.html
The second youtube video down shows how to import/export a surface analysis. That's exactly what I'd like to do.
Sooo ... my next question:
How do I get one of these handy dandy Country Kit Content Packs? And hopefully they're free, yes? (the CFO at my company is a total tightwad).
Emelendez, that was a fine and subtle point about c3d working differently depending on whether one or multiple sessions are open. Thanks. I would have never figured that out on my own. Also, the suggestion to set up my customized surface analysis in a dwg template was really good. Tried to do that, but c3d won't let you set up an surface analysis style without a "real" surface. Bummer, huh? Maybe I'll try creating a bogus, 3-point surface just so that c3d has something real to sink it's digital teeth into, instead of hypothetical nothingness. Still, I'm not keen on having anything bogus in my dwgs, especially a template. Then again, if that analysis export tool works, then maybe I won't need to put that style in a template. We shall see.
Thanks again, everybody.
And to think in the olden days all we had wer conturswith haschure marks
Some of the Country Kits come with C3D and can be installed by going to Control Panel, Unisntall a program, select C3D2012, once the dialog comes up, the lower left corner has "Add or Remove Content". Select this, the UKIE kit is the third from the last in the list.
You could create a surface, add data to it, run the analysis, and then remove the data. That might keep the empty surface with the analysis. You could then just paste whatever surface you want to run the analysis on into that surface and, badda bing badda boom, you have a surface analysis.
I create a couple "bogus" things in my templates to assist users such as pipe networks (that way you don't have to change layers every time you create a different network) and point groups.
Thanks Jeff. Tried that. I'm running c3d 2011. The UKIE kit was not listed as an option of additional content to add.
Brian - I might end up trying your suggestion if I can't find a 2011 version of the UKIE kit first.
Omg, it almost worked!
Left surface - orginal.
Right surface - target of exported surface analysis.
Dialog box - surface properties/analysis tab.
The export worked, but it seems something literally got lost in the translation. The color range in the analysis tab should all be of the same hue and saturation, but graduated in 5-point luminance increments. So, the original is basically all one color, just in incrementally lighter shades.
The target, as shown in the dialog box, has different colors (lavender and teal, not just plain ole blue). And some discrete elevation ranges are using the same color.
I opened the text file that was created using a tool from the ukie kit (as shown in that link I posted a few days ago).
the text file is very simple - 3 columns: color, elev low, elev high.
The problem is that the color field in the text file is only one field wide - just a single color code. Whereas the original color scheme used 3 fields: hue, saturation, luminance.
Neilyj - you said you got something like this to work in the ukie kit, but it didn't work the way you thought it would. Is this what you meant - the color scheme not translating properly?
Was not working for me at first either.
Dragged my surface styles in with no problems when I open both drawings in one civil 3d session.
Civil 3d 2K11
jib
Country Kits are free.
You can either add them by
If civil 3d was installed directly onto you machine from the install media
If civil 3d was installed/deployed from a deployment you can download and install individual country kits from this link
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=7271531&linkID=9240698
