I please somebody to tell me if it's possible to define the stationing of the alignment from the end of the alignment till the start.
I have a special situation where the end station is fixed in one point (ex. km 3+125,00) and till there I can change the alignment.
I want to be all the time the end in one station value.
Greetings
Solved by david.zavislan. Go to Solution.
i think its better to introduce station equation at the end of ur allignment. hope u find the resulsts :smileyhappy
click on alignment go in alingnment properties than station control and there u find the station eqation select it and locate the point where u want to insert the station equation. once added station equation it means after that station stationing will not change if alignment is changed before that staion point.
try this u will understand.
Thanks.
What I want is all my alignment from the end till the start to be changed but to have allways the final station I want.
You can do this without station equations. Go to the same tab in the Alignment Properties window. In the reference point section you can select the endpoint of the alignment and specify the station at that location. The program will calculate backwards from this point to generate the starting station for the alignment.
Check your alignment labeling after doing this. We've seen some strange results when the station control point is not in the first segment of the alignment.
