Hello all,
please advise me how to make a table from a type of label (ex: a secondary road who is intersect my design road).
I make a lot a labels to define diferent locations with some texts to understand the type of labels that are containing diferent stations.
Any king of advice it['s apreaciated.
I think I understand what it is you are trying to accomplish, but if you don't mind could you be a little more specific about what information you would like displayed in this table? What are you envisioning as far as the format of this table?
I must make diferent tables in my project to present diferent stuff and I use labels to mark this information in plan for the constructor.
To be more clear allways with the plans I give diferent tables with diferent information such diferent station positions but for the same type of object.
Ex:
1)a table for all secondary roads I have in my road and I give the side and the station position
2)a table with all the stations where a water is crossing under my road using a pipe d1000 or bigger/smaller, etc
I put a printscreen in attach maybe it's more cleare.
You can create your tables by either selecting the individual labels or using a different style for each type of information you wish to have listed seperately. ~ Mary (Pic from C3D 2012)
Hellor,
thank you for the answer but please help me to make these kind of special tables.
I can't find from where to define them.
Please write me like for the dummies 🙂
I know how to make a lot of settings in civil 3d but this one is to much for me right now.
Thanks for your efort.
Hellor again.
I want to explaine what I can't find.
I can't find this option: SELECT BY LABEL OR STYLE
Where is these option I want to find because in this way I think my problem is solved.
To get to this dialog box go to the Annotate Tab, Labels & Tables Panel, Add Tables Pull down->Alignment-> Select Add Segment.
HTH ~ Mary
Thanks for your efort but my problem is not resolved because my label is Station Offeset Label and these type of labels are not listed.
I believe it's not posible to do what I want 🙂 and all I want is to make a tabe with some stations values ... thanks again.
Oops, sorry I was going in the wrong direction for you, wasn't sure which alignment label type you were using. Station offset labels don't have a 'tag' Display Mode, so they don't have a table available. Sounds like a wishlist item for you.
~ Mary
Mary:
Rather than you apologize, think how much faster this thread would have ended with the proper information included in the first post. About 4 days I believe, Good Questions Promote Good Answers.
Bill
Your right, but I didn't know this kind of label don't have tag mode.
I think the discussion was good and I learned something about other types of tables I can make.
I apreciate the efort and I thanks to MarySeufert.
