As you can define a target for a lane width (for example) it would be possible to define a crop or limit ?
Civil 3D (2013) how much you have to improve....
In other words, you want the region start and end stations to be tied to an object? I know of no way to do that.
If you're talking about "cropping" the offset limits within a certain region, be sure your outer-most subassembly will use targets and apply targets left and right. You still have to either type or pick the start and end stations.
If you're just trying to limit what you see of the corridor surface, apply a boundary by polyline. An easy way to make that polyline is to isolate your region, add boundary to the corridor surface by extents of corridor, then extract the surface boundary. That makes a polyline that runs around only that region. Go back and remove the boundary created from corridor extents and apply a boundary created from the extracted polyline.
Tim
I'm talking about limit or cropin the offsets.
If so, you would have not to define different assemblies and different regions.
Using the boundaries is an operation you made after calculate corridor. So you have a cropped surface but not a cropped sections ....
What I want would be as a targets but with cropping . I think it would be simply to program.
mmm Thanks anyway.
You use the Conditional subassemblies for this. Those are your Switches.
Below is my one Assembly I use for county road design that addresses all main road ditch design and driveway encounters using one Region.
Dear Master,
Nice to meet you.
I would like to create a corridor then fill the hatch.
but I cannot finish the right-hand side corridor........
I use c3d 2020.........could you mind teach me how to do it?
