Civil 3D Forum
How to create the surface form contour & extract points from on it
13 REPLIES 13
Message 1 of 14
7532 Views, 13 Replies
I would like to create surface from contours and extract points (with value) from on it
I had contours in my drawing; each major and minor contours are single polyline with elevation (Z value).
If I create surface form CONTOUR, some polylines (major or minor) are not included in to surface.
After the creation of surface, I tried to erase the existing contour lines (Polyline) from drawing but the surface will be disappearing.
If I create the surface from ''DRAWING OBJECTS'', I'm not able to select the polylines (attachment 01)
Please advice
Thank you
Najeeb
13 REPLIES 13
Message 2 of 14
Adam_Farnsworth
Is it possible that all the contours were included, but your surface style had an large interval that didn't display all the contours?  (as in they're part of the definition, just not shown on the screen)
If you change the contour interval to a smaller spacing, do they appear?
Windows 7 x 64
ATI Radeon HD 5700 Series
12 GB Ram
i7 920 @ 2.67 GHz
Civil 3D 2011, 2010, 2009 and occasionally 2008 still (unfortunantly)
Message 3 of 14
in reply to: Adam_Farnsworth
Yes, now I found my mistake, Smiley Sad
I tried to erase the existing contour lines (Polyline) from drawing but the surface is disappearing. Do I need to keep these polylines in drawing ?
regards
najeeb
Message 4 of 14
Adam_Farnsworth
I believe if you right click on the name of the surface in your Toolspace, you can select Create Snapshot that will keep it as it is.
But I would recommend not deleting those lines.  Instead I would have a file dedicated to just the Existing Ground Surface (where you would keep the polylines), and then use the data shortcut to bring it into any file that you need.
Windows 7 x 64
12 GB Ram
i7 920 @ 2.67 GHz
Message 5 of 14
Adam, thanks for  your quick reply
One more thing, how about the points extracting from contours ?
regards
najeeb
Message 6 of 14
Adam_Farnsworth
I'm not sure what you mean by "extracting points," but it is possible to create points using the surface.  Here's a picture how.  I'm not sure if you'd want Random Points, or On Grid, but I'm sure you can play with both to figure out what you need.
Windows 7 x 64
12 GB Ram
i7 920 @ 2.67 GHz
Message 7 of 14
Thanks Adam, Just need this.
Message 8 of 14
test
Message 9 of 14
BrianHailey
If you are adding contour data to a surface, make sure you read this first: http://civil3dplus.wordpress.com/2011/08/13/adding-contours-to-a-surface-youre-doing-it-wrong/
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 10 of 14
gjcbachman
in reply to: BrianHailey
Brian, I read your Blog and it is very helpful.  My problem is I have a site that is very flat and has a lot of closed polylines for contours.  Instead of making them closed it is trying to connect them together.  I used the attached settings when adding the contours and still got the attached results.  I've tried many other settings with about the same results.
Any ideas would be appreciated.
Lisa
Windows 10 Pro x 64 bit
Intel Xeon CPU @ 3.8 GHz
32 GB RAM
NVIDIA Quadro P2200
Civil 3D 2020
Message 11 of 14
BrianHailey
in reply to: gjcbachman
Can you share the contours?
GEI Consultants
My Civil 3D Blog
Message 12 of 14
gjcbachman
I'm tryin to attach the contour file but I'm getting an error:  "The file is corrupted. Please udate a valid file".  I don't think there is anything wrong with it, it is about 1.7mb.
Lisa
32 GB RAM
NVIDIA Quadro P2200
Civil 3D 2020
Message 13 of 14
BrianHailey
Try using Dropbox or Google Drive (or similar service) and share a link.
GEI Consultants
My Civil 3D Blog
Message 14 of 14
gjcbachman
Brian,
Here is a link to the file on Dropbox.
https://www.dropbox.com/sh/s7ud5abga9o6kcp/QYKg--6Z9G
Thank you for your help.
Lisa
32 GB RAM
NVIDIA Quadro P2200
Civil 3D 2020
Rail Community
