Active Contributor
0 Kudos
Post 1 of 14
How to create the surface form contour & extract points from on it
5511 Views, 13 Replies
07-28-2011 03:56 PM
I would like to create surface from contours and extract points (with value) from on it
I had contours in my drawing; each major and minor contours are single polyline with elevation (Z value).
If I create surface form CONTOUR, some polylines (major or minor) are not included in to surface.
After the creation of surface, I tried to erase the existing contour lines (Polyline) from drawing but the surface will be disappearing.
If I create the surface from ''DRAWING OBJECTS'', I'm not able to select the polylines (attachment 01)
Please advice
Thank you
Najeeb
I'm not sure what you mean by "extracting points," but it is possible to create points using the surface.  Here's a picture how.  I'm not sure if you'd want Random Points, or On Grid, but I'm sure you can play with both to figure out what you need.
Valued Contributor
10 Kudos
Post 2 of 14
Re: How to create the surface form contour & extract points from on it
07-28-2011 04:07 PM in reply to: najeebcad
Is it possible that all the contours were included, but your surface style had an large interval that didn't display all the contours?  (as in they're part of the definition, just not shown on the screen)
If you change the contour interval to a smaller spacing, do they appear?
Windows 7 x 64
ATI Radeon HD 5700 Series
12 GB Ram
i7 920 @ 2.67 GHz
Civil 3D 2011, 2010, 2009 and occasionally 2008 still (unfortunantly)
Active Contributor
0 Kudos
Post 3 of 14
07-28-2011 04:34 PM in reply to: Adam_Farnsworth
Yes, now I found my mistake, :smileysad:
I tried to erase the existing contour lines (Polyline) from drawing but the surface is disappearing. Do I need to keep these polylines in drawing ?
regards
najeeb
Valued Contributor
10 Kudos
Post 4 of 14
07-28-2011 04:41 PM in reply to: najeebcad
I believe if you right click on the name of the surface in your Toolspace, you can select Create Snapshot that will keep it as it is.
But I would recommend not deleting those lines.  Instead I would have a file dedicated to just the Existing Ground Surface (where you would keep the polylines), and then use the data shortcut to bring it into any file that you need.
Windows 7 x 64
12 GB Ram
i7 920 @ 2.67 GHz
Active Contributor
0 Kudos
Post 5 of 14
07-28-2011 05:05 PM in reply to: Adam_Farnsworth
Adam, thanks for  your quick reply
One more thing, how about the points extracting from contours ?
regards
najeeb
Valued Contributor
10 Kudos
Post 6 of 14
07-28-2011 05:12 PM in reply to: najeebcad
Windows 7 x 64
12 GB Ram
i7 920 @ 2.67 GHz
Active Contributor
0 Kudos
Post 7 of 14
07-29-2011 12:15 AM in reply to: Adam_Farnsworth
Thanks Adam, Just need this.
New Member
0 Kudos
Post 8 of 14
11-21-2012 11:10 AM in reply to: najeebcad
test
Intel i7 3.4 ghz
16 GB Ram
120 GB SSD
AutoCAD Civil 3D 2012
267 Kudos
Post 9 of 14
11-21-2012 03:46 PM in reply to: najeebcad
If you are adding contour data to a surface, make sure you read this first: http://civil3dplus.wordpress.com/2011/08/13/adding-contours-to-a-surface-youre-doing-it-wrong/
Brian Hailey
CAD-1.com
My Blog
Active Contributor
4 Kudos
Post 10 of 14
06-24-2013 01:41 PM in reply to: BrianHailey
Brian, I read your Blog and it is very helpful.  My problem is I have a site that is very flat and has a lot of closed polylines for contours.  Instead of making them closed it is trying to connect them together.  I used the attached settings when adding the contours and still got the attached results.  I've tried many other settings with about the same results.
Any ideas would be appreciated.
Lisa
Windows 7 x 64
Intel i7-4770 CPu @ 3.40 GHz
24 GB RAM
NVIDIA Quadro K2000D
Civil 3D 2015
