Active Contributor
ADRooney
Message 1 of 3 (261 Views)
How to create polylines using survey data?
261 Views, 2 Replies
02-15-2013 11:26 AM
I want to create a road map using the survey data. Iv'e got some examples attached below.
Anyone please check that out and tell me how to create such type of drawings in autocad civil 3d.
ASAP
troma
Message 2 of 3 (252 Views)
Re: How to create polylines using survey data?
02-15-2013 12:05 PM in reply to: ADRooney
I don't see any attachments.
You should probably read the help files and work through some tutorials.  "Survey Figures" are what is used to create linework from cogo points in Civil 3D.
Credit where credit is due! Give kudos or accept as solution whenever you can.
Valued Mentor
IanMcClain
Message 3 of 3 (248 Views)
02-15-2013 12:07 PM in reply to: ADRooney
I'm not seeing any attachments, however, if field-to-finish linework is what you are getting at check this out:
http://docs.autodesk.com/CIV3D/2012/ENU/filesCUG/GUID-46CA2DE7-8889-42CC-AC13-1DCC9A2DA77-339.htm
-Ian McClain
(running C3D 2012 sp4, Win7 64bit, 8GB)
