I want to create a road map using the survey data. Iv'e got some examples attached below.
Anyone please check that out and tell me how to create such type of drawings in autocad civil 3d.
ASAP
I don't see any attachments.
You should probably read the help files and work through some tutorials. "Survey Figures" are what is used to create linework from cogo points in Civil 3D.
Mark Green
Working on Civil 3D in Canada
I'm not seeing any attachments, however, if field-to-finish linework is what you are getting at check this out:
http://docs.autodesk.com/CIV3D/2012/ENU/filesCUG/GUID-46CA2DE7-8889-42CC-AC13-1DCC9A2DA77-339.htm
