i am create the stron network.I want structure profile elevation.
how to create expressionin structure reference alignment profile elevation
Solved by Jeff_M. Go to Solution.
You don't need an Expression, you just need a Reference Text component in the Structure Label Style.
And then pick select Profile.
When you place the label, it will prompt you to select the profile for this reference.
Tim
i followed ur instruction. i try to shown profile elevation. But i could not get value.
Select the label, go into your AutoCAD properties, and select a reference profile.
Your Name
Your Name
i am already set strucuture refence alignment. But, how to get relavant station profile elevation..
