I would like to know how to create the drawing template in Civil 3D 2012.
Need to include some styles like profile styles (View, band, label etc.) pipe network part lists (Part, rule, label etc.).
Is it posible to include the drawing title blok also?
Please advice
Thank you
najeeb
Solved by josephbouza5497. Go to Solution.
Thank you Joseph.
On template options (attachment 01), which layer notification need to select? what does it mean?
Regards
najeeb
When you create new layers autocad give you the oportunity to check (reconcile ) the new layers for correctness. select reconcile for your template and future drawings will understand the layers.
