can any one suggest me how to create reverse curve with straight portion inbetween , as their is no option of creating reverse curve with straight portion in civil 3d , duding designing a hill road what ever the reverse curve you design will be wrong and superelevation generated will also be wrong as it do no include straight inbetween the curves (ie reverse curve should contain transition curve transition straight transition curve transition.)
Solved by MikeEvansUK. Go to Solution.
by doing so it will not be a reverse curve , you are telling me to put two curves in between straight right, i donot wat to do it in that way, i want the entire reverse curve should be a single entity ie i want to use reverse curve option in civil 3d software (civil 3d 2013)
i want to introduce a reverse curve between two parllel lines, i found in this software that there is no feature like " transition curve transition straight transition curve transition" so it will be very difficult to design the reverse curve if we introduce two different curves so i asked you is there any commend by which i can do the design of reverse curve in the above said format
Reading your post and the following threads is very confusing - you need to post a picture. Mike's solution is the only way I know how to do it and I think Euclid would also agree
ther is no such singular geometric object called a reverse curve it eithe has a tangent between or it doesn't. Since you want to apply SE your options are limited.
Draw the picture of what you think it should do ad post for us
