I have the pavement structure in the compute material volumes, but when I create a material table, I get the attached. I have no idea what material it is. All I want is something like Land desktop did, where it would have the end areas for each material with a report at the end of the quantities for each material. Is this possible? I have no idea where I'm going wrong.
Solved by alexw. Go to Solution.
Did you run the Material Volume Table command?
ADDMATERIALVOLUMETABLE or on the Analyze tab => Volumes and Materials panel.
HTH
AWood
In the Table Style => Data Properties tab, double click the Material Table title. Then change it to Material name.
That will tell you which material that table shows.
You'll have to create a table for each material which is selected when you add the material volume table.
If that's not what you're looking for, maybe a bit more explanation, and attach the drawing?
HTH
AWood
Ah, I had the Material Table set all wrong. Thanks for setting on the correct path! I was getting frustrated. It's all working now. Thanks again!
Your Name
Your Name
