That tool is meant for something else. It may help a bit, but setting the
mid-ordinate distance to a smaller number, I believe, is the generally
accepted best practice just just this scenario.
Matt Kolberg
Global CADD Systems - A division of Cansel
"Robert" wrote in message
news:6330539@discussion.autodesk.com...
> Would "minimize flat areas" help?
> "Matt Kolberg" wrote in message
> news:6330502@discussion.autodesk.com...
> A different (I like this better) is, when you're adding those to your
> surface as Standard breaklines, you will see a Mid-Ordinate distance
> value.
> The smaller you make this number, the more tessellated your feature line
> will be, thus it will more closely match your curve.
> Doing it this way will not force you to modify the feature line which , in
> my opinion, shouldn't be done if at all possible.
> Matt Kolberg
