Question- how do I convert a section that I created using an alignment and surface into a polyline. I want to be able to manipulate and easily use the section for another program. Thanks
If the exploding scares you, try Export Civil 3d Drawing.
It will export your Civil 3d objects as base AutoCAD entities. It also allows you to send it backwards in versions. This helps when you need to send it to another program that doesn't have the most recent updates, or to a client who is lagging behind in their AutoCAD versions.
Located in a few places. Under the application button export options, or just use _EXPORTC3DDRAWING.
~Andy
