JamaL9722060
Message 1 of 4 (265 Views)
How to construct a table to lay out the "horizontal curve" on the ground?
265 Views, 3 Replies
09-18-2012 01:19 PM
The steps that follow the design of the horizontal alignment is to set up it on the ground. For this purpose a table that contains angles and distances is established to set up the curve on the ground. I have no idea how this process is performed on the C3D
Thank you
Best
Jamal
Jamal NUMAN, GIS and Civil Engineer, MSc
e-mail: JamaL9722060@yahoo.com
P.O.Box: 731, Ramallah, West Bank, Palestine.
Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
Windows 7 (Ultimate 64 bits),
Firefox 20.0,
Kaspersky 2013.
sboon
Message 2 of 4 (263 Views)
Re: How to construct a table to lay out the "horizontal curve" on the
09-18-2012 01:27 PM in reply to: JamaL9722060
Are you sure that a table like this is necessary.  I have not seen a surveyor using this technique for curve layout in the last thirty years.
JamaL9722060
Message 3 of 4 (232 Views)
09-19-2012 10:21 AM in reply to: sboon
Thank you for the answer Steve.
Then how to lay out the horizontal curve on the ground?
Suppose you have a “total station” and you need to lay out horizontal curve then you need a table that contains angles and distances to be able to “fix” the points of the horizontal curve on the ground.
Is there other way in this case?
Firefox 20.0,
Kaspersky 2013.
sboon
Message 4 of 4 (229 Views)
09-19-2012 10:31 AM in reply to: JamaL9722060
In modern survey the instrument is typically set up over a control point which can be in any convenient location.  If the alignment information is supplied then the equipment has the ability to calculate the angles and distances to any point "on the fly."  The only thing that the surveyor needs from me is an alignment and profile in xml format.
