I would like the contour line colored to reflect the elevation it is depticting! I have successfully used surface properties - elevations - to create ranges, and to FILL color in between contours, but is there a workflow to color the contours themselves?
i also noticed, within the same dialogue box in surface properties, a contour pull down - but it doesnt have near the control to set elevation ranges, nor does actually effect the contour color.
any ideas?
TIA, OA
Solved by Neilw_05. Go to Solution.
