Active Contributor
darreng_oa
Message 1 of 3 (442 Views)
how to color a contour relative to the elevation
442 Views, 2 Replies
12-11-2013 06:21 PM
I would like the contour line colored to reflect the elevation it is depticting! I have successfully used surface properties - elevations - to create ranges, and to FILL color in between contours, but is there a workflow to color the contours themselves?
i also noticed, within the same dialogue box in surface properties, a contour pull down - but it doesnt have near the control to set elevation ranges, nor does actually effect the contour color.
any ideas?
TIA, OA
Under the Analysis tab of surface properties there is a Contour analysis. Apply a color scheme to the contours.
In the surface style settings you'll need to turn on the color scheme display. Go to the contour tab and under the Contour Range group, set "Use Color Scheme" to True.
Neilw
Message 2 of 3 (423 Views)
Re: how to color a contour relative to the elevation
12-11-2013 08:46 PM in reply to: darreng_oa
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
Active Contributor
darreng_oa
Message 3 of 3 (343 Views)
12-21-2013 12:30 PM in reply to: Neilw
sorry to respond so late!
