How to choose “no color” for the line extending between the contours labels?
I labeled the contour lines but sounds that it draws a line between them. Is there a way to hide this line to give it “no color” to have a better presentation for the entire map?
Thank you for the help,
Best
Jamal
You don't give it a 'no color', you set it to be visible or not.
Thanks Jeff.
i provided my further comments in the thread you have already provided
best
Jamal
I don't know if you look for help before posting here, if you don't you should consider it. The first thing I typed into Google found this very first link. I typed in "Civil 3D Contour Label Line".
http://civil3dplus.wordpress.com/2010/02/11/those-pesky-contour-label-lines/
If you do a quick search yourself before posting here, you'll save yourself some time instead of waiting for a reply here. I'm just saying is all, I found the answers to all of your posts today in about 22 seconds. The trick is to type Civil 3D before a few words that are meaningful to your problem.
Why wait here if you can have your answers now?
I actually searched for an answer to a problem I was having and it took me to my own blog. I suppose it was bound to happen.
