Civil 3D Forum
How to change the sequence of the input/out parameters in Subassembly Composer?
5 REPLIES 5
civilgz
1404 Views, 5 Replies
When I created my subassembly with subassembly composer, it's difficult to change the sequency of the input/output parameters. Do we have an easy way to do that, Like moving? Thanks.
5 REPLIES 5
david.zavislan
in reply to: civilgz
To change the order that they appear in SAC, you can edit the .xaml file contained in the pkt archive file.  You can cut and paste the order of the Property elements.
To control the order that they appear in the PROPERTIES window in Civil 3D, edit the atc file that is in the pkt archive file.  Cut and paste to change the order of the params elements.
Back up the pkt file before making these edits, because it is real easy to mess up the xml files.
David Zavislan, P.E. | Wood Rodgers, Inc.
in reply to: david.zavislan
Where is the pkt archive file and how do i open it?
Right click on .pkt file >  7-ZIP ( or other archive you are using) >>>> open archive there you will find all files.
Thanks for your fast reply!
CNinBC
is there a way to adjust the target sequence in the corridor target dialog box for custom subassembly? for example, i would like to switch the order of the target for Front and Back of Sidewalk on the image attached below. the method mensioned in your post only change the sequence of the target parameter in the composer, not the one on the target setting dialog box.
edit: Sorry, it's my fault, it does change the sequence of the target parameter in the corridir target window.
Rail Community
