How to change the number of decimal places of the elevation of points?
as the points are labeled with their elevations, I couldn’t find how the number of the decimal places of the elevation be chosen. In this case, I wanted to let the number of the decimal places to be zero.
How to set the number of the decimal places to be zero or 1, for example? how to sepcify it height (size)?
Please, have a look on the screenshot below.
Thank you for the help,
Best
Jamal
Solved by sjg. Go to Solution.
Thank you for the answer.
I tried it but sound to not have an effect on the precision of the elevation of the points label.
what might be the problem?
the file is attached
best
Jamal
Many thanks for the answer.
still I’m confused in how to control this precision! where might be the tab that controls the precision?
Many thanks sjg for the help. finally it did work
sure, the screenshots is the best way to deliver help. I appreciate your effort.
best
Jamal
