Civil 3D Forum
How to change the number of decimal places of the elevation of points?
6 REPLIES 6
JamaL9722060
41654 Views, 6 Replies
as the points are labeled with their elevations, I couldn’t find how the number of the decimal places of the elevation be chosen. In this case, I wanted to let the number of the decimal places to be zero.
How to set the number of the decimal places to be zero or 1, for example? how to sepcify it height (size)?
Please, have a look on the screenshot below.
Thank you for the help,
Best
Jamal
Jamal Numan
6 REPLIES 6
In the Settings of your Toolspace, right-click on the drawing name and select Edit drawing settings.  Once there, click on the Ambient Settings tab.  This is where you will change the precision.
Todd Rogers
Thank you for the answer.
I tried it but sound to not have an effect on the precision of the elevation of the points label.
what might be the problem?
the file is attached
best
Jamal
Jamal Numan
sjg
in reply to: JamaL9722060
You need to change the precision in your point label style. Go to your setting tab of your toolspace.
Steve Goessling
Land Consultants
Civil3D 2015
Windows 7, 64 bit
Intel i7 2600 @ 3.40Ghz
16 GB RAM
Nvidia Quadro 600
JamaL9722060
in reply to: sjg
Many thanks for the answer.
still I’m confused in how to control this precision! where might be the tab that controls the precision?
Jamal Numan
sjg
See if this helps. Now I am showing changing the Standard label style, you will have to choose the correct one if you have multiple.
Steve Goessling
Land Consultants
Civil3D 2015
Windows 7, 64 bit
16 GB RAM
Nvidia Quadro 600
JamaL9722060
in reply to: sjg
Many thanks sjg for the help. finally it did work
sure, the screenshots is the best way to deliver help. I appreciate your effort.
best
Jamal
Jamal Numan
Rail Community
