Civil 3D Forum
How to change sequence of input/output parameter in Subassembly Composer 2013
5 REPLIES 5
civilgz
2150 Views, 5 Replies
I hope Autodesk can have a easier way to edit the "input/output parameter" sequence. Today I found I cannot even delete a parameter. Whenever I want to delete a parameter, SAC just frozen.
5 REPLIES 5
dnietubicz
in reply to: civilgz
I would also like to re-order the parameters. What a pain it is to look through the properties to try to find something when its in no definable order. BTW The only way to delete parameters is to close out SAC and re-open SAC and delete the unwanted parameters before you do any other commands. Doug
david.zavislan
You can change the parameter order manually by editing the .atc file contained in the subassembly pkt file.   Use Notepad or another text editor to reorder the <Params> group in this file.  (I would make a backup copy of the pkt file first.)
The pkt file is just a zip file containing all of the data files used to define the subassembly.
David Zavislan, P.E. | Wood Rodgers, Inc.
fcernst
in reply to: david.zavislan
Great tip.
I had to edit the XAML file also to get the parameter reordering to work.
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
saifumk8
How to open .atc file from .pkt file?
See attached screenshot, then simply rename .pkt to .zip
then edit atc file and again drag into zip file.
later again .zip to .pkt and import to civil 3d.
Rail Community
