Civil 3D Forum
How to change colors of Contour lines-different surfaces
5 REPLIES 5
4413 Views, 5 Replies
I have created two surfaces in separate sites. I was trying to make the "existing" surface contour lines different colors from the "proposed" contour lines because the two surfaces overlap. When I tried changing the colors of one under "Edit Surface Style", it changed both surfaces. Can I make them different colors?
5 REPLIES 5
doni49
Yes but you need the two surfaces to be DIFFERENT styles.
We have a style for Existing Surface and another style for Proposed Surface.  The colors & lineweights for each are different.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Jeff_M
Yes, assign 2 different styles to the surfaces, change each one as desired.
Jeff_M, also a frequent Swamper
in reply to: doni49
So, my follow up question would be, how do you change the surface style once the surface has already been created?
Scratch that, I figured it out. Go to Surface Properties after right-clicking on the appropriate surface in Toolspace.
homidomid
Thank you very much , this was helpful i had the same problem by reading this posts it has solved .
Regards
Rail Community
