Civil 3D Forum
how to apply colors to "subassembly shapes" in Subassembly Composer
3 REPLIES 3
civilgz
2094 Views, 3 Replies
When I create shapes in subassembly composer, I want to apply different colors to the shapes. How can I do that? Thanks.
3 REPLIES 3
KMercier_C3D
in reply to: civilgz
You will get different colors if the shapes are assigned different Shape Codes. You won't have the ability to chose what color is assigned but they will be different.
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
The color is assigned based on the shape code and the code set style that is assigned to the assembly, or corridor, or section.
David Zavislan, P.E. | Wood Rodgers, Inc.
civilgz
Thanks.
Rail Community
