How to adjust the length of band borders to avoid overlapping of band labels and band borders?
Solved by marlance. Go to Solution.
Solved by Jay_B. Go to Solution.
If you mean at chainage 283.09 on the right margin of Profile View, then adjust the Stations Tab in Profile View Properties to "User Specified Range" and set End Station to 300 or greater.
No need to adjust the alignment, set the Grid to an even station such as 300 by specifying a user specified range in profile view properties should clean up the overlap.
how to adjust the length of band border in cross section not in profile it possible please help me
