Hi folks,
I'd like to use a custom block to represent a curb inlet. It needs to do two things:
1. Pull an elevation from the middle of the back of the block to use as the "TOP" elevation. Put another way, the TOP elevation needs to reflect the back of curb elevation. Right now, this is working fine. See attachment 1.
2. The connected pipes need to connect at the center of the block. Right now, they are connecting at the same location as #1. See attachment #2.
So, my question is: how to preserve #1 and correct #2?
Solved by odoshi. Go to Solution.
To make the pipes connect at the centroid, you need to redefine the base point of your block. I'm sure if you inserted that inlet structure as a block, the grip would be at the back center. You need it to be at the centroid of the block.
This of course will change where the elevation is read from, so you will need an expression to add the .5 foot additional height from the grate to the back of structure. Then use that expression in your labels.
Mike
