Civil 3D Forum
how to add text to a formula in a table
3 REPLIES 3
aluko0719
2002 Views, 3 Replies
i have a table with a simple formula =sum(b3:b16) the formula works fine what i want to do is after the formula i want to add text. if the value of the formula is 22 i want the cell to read 22 V.F. i'm using civil 3d 2014
3 REPLIES 3
tcorey
in reply to: aluko0719
Right click, Insert Field.
Field category: Objects. Field Name: Formula. Type the formula, then press Addtional Format. In the Suffix box, type V.F.
 Ok all the way out to the command prompt.
Best regards,
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Joe-Bouza
To add to Tims post: press the additional format button and you can add a suffix
Joe Bouza
aluko0719
thanks that works
Rail Community
