Civil 3D Forum
how to add surface to an existing profile view
5 REPLIES 5
millermccoy
24448 Views, 5 Replies
I've got a profile view created with one surface and I would like to add a different tin surface...and keep the one surface already on it
thanks!
2015 Civil 3D
5 REPLIES 5
Jeff_M
in reply to: millermccoy
Sample the new surface, it should automatically show up in the existing PV.
miked
Profile - Create Profile from Surface
Then select the same centreline as the centreline in the profile you want to add the new surface
Select the surface you want to add and then add
Select draw in profile view and its there now just cancel out of the rest and done.
NVIDIA Quadro 600
Civil3D 2012 64x
mathewkol
in reply to: miked
"Draw in profile view" does not need to be selected.  It will just show up.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
nidhinksur
Select the alignment and add the surface from the Surface Profile option on the top ribbon
pjconesaVP98G
in reply to: nidhinksur
This worked perfectly for me. The only issue is that the bands does not update automatically, I have to access view profile props and click ok in order to get the band updated.
Rail Community
