I'm a beginner in Civil 3d, we are about to start in a new project which include demolishing of old road and renew all road items asphalt, curbstone exits/entries between service road and main carraigeway.
In my case I have a new design of road with full detailed curbstyone lines and exits and entries.I won't make a new design , the problem is how to project new design lines their elevations into autocad civil 3d.
I am assuming you have had no training in Civil 3D. As a minimum, you need to locate the TUTORIALS located at the top of the Civil 3D screen.
Start from the beginning and do these.
Bill
Welcome to the forum!
Just to expand on Bill's reply just a little bit, go through the tutorials on Surfaces, Alignments, Profiles & Corridors.
If you have any questions along the way, come back and ask (start a new topic for each new issue). Someone will assist.
Don Ireland
Engineering Design Technician
What format do you have the new design in? New design, even for a rehab project, is usually done using a Corridor. It sounds like you have the design from other sources and are asking how to draw it at elevation.
Allen
Allen Jessup
CAD Manager - Designer
