can anyone help me. I would like to add a 3rd Vertical axis in profile view.I would like to add another vertical axis besides the start and end axis because i have 3 miles profiles that i am going to print on 36" by 96" sheet through one view port.
Thank you in advance.
Sounds like you want to split the profile view. See the Elevations tab of Profile View Properties.
Perhaps Tim answer is better but I am not sure how the splitting will work. Here is what I would do except I have never had a profile that long. From your note it appears to me that you want 1/2 of the profile above the other 1/2.
Make your profile 3 miles long.
Copy the above and use the STATIONS tab and set the beginning at 0+00 or where ever you want to start.
Copy this shorter profile and set it's starting station to where the other one ended.
Set these two one above the other and place your viewport around it.
Bill
