Civil 3D Forum
How many of you will upgrade to 2013 immediately?
13 REPLIES 13
Message 1 of 14
deltacoolguy
912 Views, 13 Replies
Got my link for the 2013 subscription upgrade this morning.
How many of you will upgrade immediately?
Normally, I wait a couple months, but I pretty much ignored 2012 and stayed with 2011, and am considering doing it now and getting it overwith.
Windows 10-64 Pro
8GB RAM (Home)
12GB RAM (Work)
AutoCAD Civil 3D 2019
13 REPLIES 13
Message 2 of 14
neilyj666
in reply to: deltacoolguy
I'll be getting the CUI/customisations/template migrated over the next week or so and then run with 2013.  The 2012 release has been more stable than 2011 so hopefully 2013 with maintain this...
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 3 of 14
It will be awhile for us since the file format changed (along with the API) we will have to recompile all our applications.
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
Message 4 of 14
Sinc
I never recommend an immediate upgrade, unless you are masochistic, like wfb...  🙂
But it can depend a lot on the size/extent of your projects, as well as the size of your company, and how many other tools you utilize in addition to C3D, and on how many other companies you work and share data with on a close basis.  So there's no hard-and-fast answer.
I typically jump to the latest version early for Sincpac-C3D testing.  But we typically wait until winter (or when work is the slowest) to roll out the latest release of C3D at Edward-James Surveying.  That gives the masochists (like Bill) time to fight all the major bugs, and we usually have SP1 available by then.  This past two years have been a bit of an exception, though...  We were really busy all through winter 2010-2011, then had a slow-down in June (very bizarre for Colorado).  So I ended up rolling out 2011 last summer, because I was too busy during the winter.  2011 proved to be a very bad release (IMHO), so I've now rolled out 2012, even though we're very busy again - 2012 is so much better than 2011 that it was worth taking time out to get it deployed.
Haven't yet been able to determine how good a release 2013 is.  But as a general rule, I would not be in a hurry to roll it out prematurely, ESPECIALLY with the DWG format change, and the yearly incompatibility, at least if you often work with other companies.  Nothing worse than trying to work with a company that hasn't yet upgraded...  Even worse, if you force them to move up to 2013 to stay compatible with you, and then things come back to bite both of you, YOU'RE the one who looks bad.
I know it's difficult to test a new release without rolling it out company-wide...  After all, in these days, who has time to waste, recreating existing projects in the latest release of C3D?  But it's definitely the safest course, at least if you intend on switching to C3D 2013 in the next few weeks (before there's time for community feedback from the masochists).  If you wait at least a month before rolling it out company-wide, you at least stand a good chance of finding solutions to major problems in the newsgroups/forums.  If you roll it out right now, then GOOD LUCK....
Sinc
Message 5 of 14
TerryDotson
Don't forget that once you save those drawings, they are useless to those running 2012, 2011, etc.
Message 6 of 14
cwitzel
We are a very small shop so I usually upgrade pretty quickly.  Sometimes I install on my computer for a couple of weeks of testing before rolling it out.
I may skip that this year as we just got a new computer for another designer.
My thinking right now is I will wait a bit and install 2012 on the new computer mainly for the GE stuff, which we use all the time.  In addition the Design Suite has not been released yet.
Conan Witzel
Windows 7 64 bit
Design Suite 2012
Conan Witzel
Civil 3d 2021 SP1.1
Smoking BOXX Apex 2 Workstation
Message 7 of 14
We always have 1 or 2 computers loaded immediately and assign some projects which will be used to test out behavior of software and any other changes. Once we are comfortable after a few weeks we just move on. Some new projects starting after this release will be started with new software. You got to have a few guinea pigs in every office! AutoCAD 3D as had better versions each year! We are dedicated users all the way.
Message 8 of 14
I always wait a few weeks before I install it on everyones computers. While I'm waiting im running test on my work PC.
tony
CAD Manager
www.tonyscivil3dworld.blogspot.com
Message 9 of 14
wfberry
in reply to: Sinc
I certainly would like to thank "sinc" for his kind remarks.  Working great so far, but since I don't have much going on, it is hard to tell.
Smiley Very Happy
Bill
Message 10 of 14
in reply to: michael.robertson
Mike, is there a target date for that to happen, i.e., for a FDOT Statekit 2013 release?
Message 11 of 14
Sinc
in reply to: wfberry
Smiley Very Happy
Bill
We actually really LIKE having masochists like you...  I'm sure Autodesk enjoys it even more.
Yep, I've now coined a new synonym...  "Autodesk Latest-Release Early-Adopter" = "Masochist"...  Just hope it also doesn't = "Insanity"...  Smiley Very Happy
Sinc
Message 12 of 14
wfberry
in reply to: Sinc
Would that give me an MBA?
Bill
Message 13 of 14
Sinc
Bill
Which one?  "Masochistic By Alot"?  "Mashochistic But Adorable"?  "Masochistic Bad-****"?
Sinc
Message 14 of 14
deltacoolguy
I want to be "cutting edge" (for a change), but the reminders of the wisdom of waiting are well-taken, too.
I'm going to go ahead and load and confogure it, but not fully commit new projects just yet.
Windows 10-64 Pro
8GB RAM (Home)
12GB RAM (Work)
Rail Community
