Active Contributor
johnthoreson
Message 1 of 9 (837 Views)
How is the Autosave function supposed to work?
837 Views, 8 Replies
01-11-2013 04:12 PM
2013 C3D crashes on me a little less than once a day.  Fatal errors and recoveries are also quite popular.  Today, the crash took Windows 7 down with it too - a rare treat.
I have Autosave set to 20 minutes and also have the box for creating a backup file with each save checked under Options > Open and Save.
When Drawing Recovery Manager opened today, the dwg I was working on says it was last saved over 1.5 hours ago.  The bak file was last saved yesterday.  Usually, there's a sv$ file, but not this time.  The sv$ file is typically the most up-to-date file.
Shouldn't I see a "last saved" time and date of about 30 minutes ago for my dwg?  Same for the bak file?  Is there some other variable that I need to set?
John Thoreson
C3D 2013
sboon
Message 2 of 9 (824 Views)
Re: How is the Autosave function supposed to work?
01-11-2013 06:44 PM in reply to: johnthoreson
There is a known issue with the Publish command that may be causing your problem.  When the Publish operation is running the Autosave function is turned off to avoid conflicts.  Sometimes the Autosave is not reset properly, so it stays off.
neilyj
Message 3 of 9 (813 Views)
01-12-2013 12:25 AM in reply to: johnthoreson
get into the habit of using ctrl+s to avoid problems.
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Active Contributor
shunter62
Message 4 of 9 (770 Views)
01-14-2013 08:37 AM in reply to: johnthoreson
Your Temporary File folder may be full of clutter & old files. If you are saving every 20 minutes in an 8 hour workday, that's 24 files per day. That's a lot of old stuff.
If you are a fanatical housekeeper and your temp files are removed often, then apologies in advance. Happy New Year.
Active Contributor
johnthoreson
Message 5 of 9 (759 Views)
01-14-2013 10:24 AM in reply to: shunter62
Thanks everyone for your input.  Sounds like it could be a number of things.  Using Ctrl + S more often is probably the best workaround.
John Thoreson
C3D 2013
Valued Mentor
KirkNoonan
Message 6 of 9 (748 Views)
01-14-2013 11:21 AM in reply to: johnthoreson
After crashing, it doesn't hurt to verify that your autosave setting (among others) is still the same as you intend it to be. Sometimes settings will change after (during?)a crash. Autodesk likes to test us like that.
Valued Contributor
MSBryan
Message 7 of 9 (738 Views)
01-14-2013 12:00 PM in reply to: johnthoreson
Here's a link to some potential procedures that may help alleviate some of the pain in this process.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Automatic-Save/td-p/2394334
Active Contributor
johnthoreson
Message 8 of 9 (685 Views)
01-28-2013 09:20 AM in reply to: KirkNoonan
Good point.  I've noticed that often the FILEDIA variable resets itself to 0 after a crash.
As for Autosave, I'm trying out leaving it off and relying on using Ctrl + S instead.  During the last couple of crashes where Autosave was on and appeared to be working (in the middle of a command the program would pause while it saved), when I restarted the program the Autosave files that I thought were made 15 minutes ago simply weren't available.
John Thoreson
C3D 2013
Active Contributor
johnthoreson
Message 9 of 9 (668 Views)
01-28-2013 12:17 PM in reply to: MSBryan
Thanks for the link!
John Thoreson
C3D 2013
