Civil 3D Forum
how i get existing profile
10 REPLIES 10
Message 1 of 11
551 Views, 10 Replies
please how do i configure my profile so that the EXISTING ELEVATION LEFT, EXISTING ELEVATION RIGHT,EXISTING ELEVATION CENTER AND FG ELEVATION WILL APPEAR AT THE BOTTOM OF MY PROFILE  SIMULTANEOUSLY
10 REPLIES 10
Message 2 of 11
doni49
Create an alignment for each of those items and then project each alignment to the desired profile view.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Message 3 of 11
Jeff_M
Create a copy of the Band, set the offset to be -25, set all of the Text components to not be visible, add 2 new text components, set the first to be for Profile 1, the other for Profile 2. Set the attachment for the first to be connected to the second profile of the last original text component, set the second one to be connected to the first new one....Make sense? Then you can select 2 different profiles for this band's labels.
Jeff_M, also a frequent Swamper
Message 4 of 11
thanks for your reply
is little confusing
can you show me step by step
thanks
Message 5 of 11
Jeff_M
Here's a video showing the steps:
Ad a link to the original in case this is too small:
Message 6 of 11
in reply to: Jeff_M
Thank u for your selfless service. i really appreciatd.
it works but i was looking for something like this
Message 7 of 11
Jeff_M
So you want the bands to be like this?
Message 8 of 11
Jeff_M
Attached is your drawing with the bands setup as your csv dispayed.
Message 9 of 11
please sir can you explain more on this i cant get it. what steps do i need to take to achieve this.
thanks
Message 10 of 11
Jeff_M
Did you examine the dwg I posted? It uses 4 band styles, each with a differnt title, with just the bottom one having the station component set to display. Then in the profileview properties, bands tab, set each of the bands to use a different profile.
Message 11 of 11
waoooooooooooooh that is it. am very greatful. thanks alot
Rail Community
