please how do i configure my profile so that the EXISTING ELEVATION LEFT, EXISTING ELEVATION RIGHT,EXISTING ELEVATION CENTER AND FG ELEVATION WILL APPEAR AT THE BOTTOM OF MY PROFILE SIMULTANEOUSLY
Solved by Jeff_M. Go to Solution.
Create an alignment for each of those items and then project each alignment to the desired profile view.
Don Ireland
Engineering Design Technician
Create a copy of the Band, set the offset to be -25, set all of the Text components to not be visible, add 2 new text components, set the first to be for Profile 1, the other for Profile 2. Set the attachment for the first to be connected to the second profile of the last original text component, set the second one to be connected to the first new one....Make sense? Then you can select 2 different profiles for this band's labels.
Thank u for your selfless service. i really appreciatd.
it works but i was looking for something like this
Did you examine the dwg I posted? It uses 4 band styles, each with a differnt title, with just the bottom one having the station component set to display. Then in the profileview properties, bands tab, set each of the bands to use a different profile.
