This looks like it creates a surface that is identical to the one that gets created by using LandXML. At least, I see no breaklines in the surface. It looks like it simply pulls in a TIN, just like LandXML. Is that correct?
Also, I'm assuming we must use LDT 2008 in order to extract data from C3D 2008 objects. Will LDT 2008 also extract entities from C3D 2007 drawings?
All in all, this looks like the best method. We can export the DWG to Autocad, letting C3D flatten everything and get rid of all the C3D entities. Then we can also extract the data into a project. Then send the client both the Exported drawing and the zipped project.
That seems to be a whole lot easier than constantly explaining how to use LandXML, then suffering the wrath of the client who does not want anything to do with LandXML and blames us for making their life difficult, which is what usually happens when LandXML comes up. True, LandXML may be simple enough, but for users who are still using R2000 software and maybe 10% of Land Desktop's capabilities, avoiding LandXML and giving them their old comfortable LDT project is by far the easiest course.
And as I've said before, when clients get data in a format they are not familiar with, they automatically assume it's bad data, and they stop using us as a survey firm. That's something we can't afford. So if we have to go through the pain of starting up Land Desktop, extracting data into the LDT project, exporting a file to Autocad 2007, and then sending all that to the client, that's better than having them assume we're giving them garbage because they don't know what a .XML file is.
Sinc
