This is a new road tying in to an existing edge of pavement. It ties in to the existing just fine, but I can't figure out how to fix the waterfall between sta 41 and 51? Any suggestions?
David
Solved by dtomberlinhof. Go to Solution.
Solved by neilyj666. Go to Solution.
Check that your desigb profile is EXACTLY the same length as your EGL profile that you are using for the corridor
neilyj (No connection with Autodesk other than using the products in the real world)
Went back and checked the profile and sta 0+00 to 0+65 are gone. Which has me wondering how that happened. But I think when I fix that it'll solve my problem.
