So I'm downing on a design layout and I'm not sure what I pressed but I accidentially turned on some drawing setting with a whole lot of information I don't need and its getting in the way.
Attached is a screenshot of the extra crap that is added when trying to draw a line
Solved by neilyj666. Go to Solution.
What version of C3d?
It looks like you turned the transparent command "Line by Angle Dist" on. Did you try esc. twice?
Reid
Looks like DYN input has been turned on - F12 to toggle on/off
neilyj (No connection with Autodesk other than using the products in the real world)
