Solved by sboon. Go to Solution.
The description sounds like a problem hiding the existing surface within the corridor extents. The simplest solution would be to use the surface boundary from the corridor as a mask in the existing surface.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Here's an example from one of the tutorial drawings.
Steve
