Civil 3D Forum
how do I import a shape file into 2010?
11 REPLIES 11
Message 1 of 12
albionpjl
17149 Views, 11 Replies
So first I want to import a shape file. It used to be on the map drop down, but I don't have a map drop down soooo....
I can actually access the help files for this but they are useless.
it says:-
To import SHP data
Use the Import instructions.
so I click on import instructions link to read this:-
To Import any other file type. Click Insert-Import panel-Map Import .
Continue with the following steps.
trouble is, the import panel does NOT have a mapimport button!
Has anyone solved this?
thanks
11 REPLIES 11
Message 2 of 12
in reply to: albionpjl
Change your Workspace to "Tool-based
Geospatial"
Bill
style="BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px">
So
don't have a map drop down soooo.... I can actually access the help files for
this but they are useless. it says:- To import SHP data Use the Import
instructions. so I click on import instructions link to read this:- To Import
any other file type. Click Insert-Import panel-Map Import . Continue with the
following steps. trouble is, the import panel does NOT have a mapimport
button! Has anyone solved this? thanks
Message 3 of 12
Real Map user just type MAPIMPORT at the command
line.
That's what they tell me. : )
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Geospatial"
Bill
So
I don't have a map drop down soooo.... I can actually access the help files
for this but they are useless. it says:- To import SHP data Use the Import
Import any other file type. Click Insert-Import panel-Map Import . Continue
with the following steps. trouble is, the import panel does NOT have a
mapimport button! Has anyone solved this?
thanks
Message 4 of 12
albionpjl
Thanks to the Bill with the helpful answer.
Got it.
Murph?
I have just spent several hours trying to get toolbars and legacy button settings into this program.
I still can't find the Format options, and half the help files just throw up errors when I try to use them.
Jokes are not really appreciated right now!
I do most old commands by the command line, but I have lost the ability to remember new ones; my brain is full.
Message 5 of 12
Joan:
Don't be too tough on Murph.  If you add up
all his qualifications (published), he would be over 112 years old, but he is
quite useful here, we need him.
BTW,  MAPIMPORT does work.
<G>
Bill
to the Bill with the helpful answer. Got it. Murph? I have just spent several
hours trying to get toolbars and legacy button settings into this program. I
errors when I try to use them. Jokes are not really appreciated right now! I
Message 6 of 12
albionpjl
mmm
wasn't intended to be really tough.
Sorry Murph if it came out over-narky. It's bloody Autodesk I'd like to do bad things with sharp implements to!
I know the command line commands work, but the help files that would enable me to find them when I need them don't.
I really have reached my limit on commands to learn (THAT age, y'know, brain turning into toffee for the next few years) and I had 2009 all nicely set up with a toolbar for the map commands (insert shape files, clean drawing, export to shp, boundary trim)
Can't find where they've hidden any of them now, can't even change windows easily,
help files either blocked (by our internet security) or about as helpful as a squashed radish would be, and I'm about ready to throw my A1 digitising tablet through my screen!
Been trying (without success) to add window and format to the screen menu thing, but can't make head or tail of the so-called help.
Got almost nothing done all day which means stretching the truth on my timesheet, as pratting about with altered programs is not something 'they' budget for.
Now going home to swear at the cat! Edited by: albionpjl on Jun 8, 2009 5:46 PM
Message 7 of 12
No offence taken, it's Monday I wait until wed
before I get offended and put on my suit of armor.
One tool that might help you find the command or
buttons on the ribbon is the command locator, way over to the right side with
the big ? on the drop down list "Where is My Command" .
mmm
wasn't intended to be really tough. Sorry Murph if it came out over-narky.
It's bloody Autodesk I'd like to do bad things with sharp implements to! I
to find them when I need them don't. I really have reached my limit on
windows easily, help files either blocked (by our internet security) or about
digitising tablet through my screen! Been trying (without success) to add
so-called help. Got almost nothing done all day which means stretching the
something 'they' budget for. Now going home to swear at the cat! Edited by:
Message 8 of 12
BTW if you are the command line type and forget
some of those commands that you don't use all the time, type in the first few
letters of the command or what you think it is and press the tab key, it
will cycle though all the commands that start with those letters.
mmm
Message 9 of 12
albionpjl
Thanks Murph,
I'll check it out tomorrow.
I just crashed out of the whole program while trying to find a way to drag those legacy menus onto the screen menu.
So it's definitely home time. I've donated enough of my time to the company for one evening.
At least TOMORROW evening I can hit a punchbag or two.
and this post reply keeps malfunctioning too!
Message 10 of 12
Murph wrote:
> Real Map user just type MAPIMPORT at the command line.
Proud to say I've lost a *second* looking for an icon.
Long live the command line.
Terry
Message 11 of 12
albionpjl
Thanks, that's a handy feature; found a few lost things with it. 🙂
Pity they only included a selection of the menus on it and not all. Edited by: albionpjl on Jun 9, 2009 10:00 AM
Message 12 of 12
apatceg
I just wanted to interject for a moment to help Albionpjl out.  I wasn't sure how to change the workspace that Murph was talking about, so I just typed WORKSPACE.  It worked and brought up a few commands that included an EDIT command.  I typed "e" and then a window popped up.  In the upper left portion of the window was the Customizations in All Files window.  Under workspaces is the "Tool-based Geospatial" option that Murph was referring to.  Right click on it and set current.  Then hit OK.
When I navigated to the import tab again it had changed and I saw many of the options I was expecting to see all along.  I hope you're able to get done what you're trying to.  Good luck!
Rail Community
